Originally Posted by
Dsenterfitt
The machine has been hooked up and running for 7-8 years on 3phase, my guess is a power surge, I checked the power coming in to the lathe, checked power going to the drive, the voltage is right. Took the spindle motor off and sent it off to be checked to make sure it didn't cause the problem, it checked out good. I couldn't find any other issues with the machine that would cause the drive to go out. We got the A1000 drive in ,he said it was just going to be plug and play I didn't really believe that but anyways. My problem is that first the spindle wouldn't turn on by the fanuc controller, now it will but when you type in m3s2000 for forward 2000rpm it is only actually turning and reading 672rpms same for the m4 reverse command. It will let you jog X&Y when the spindle isn't running, but when you go to run the program it won't move X&Y when it turns on the spindle, if the spindle isn't on it will move X and y. It has to be in the parameters. We had a Yaskawa tech come today, and he said it's in the parameters. but he doesn't know what to set them to because he doesn't know what the settings was in the old Drive so basically we paid him 150 an HR for 6hrs for nothing
Sent from my Z982 using Tapatalk
