Problem Interact 1 MKII TNC 2500
Results 1 to 2 of 2
Thread: Interact 1 MKII TNC 2500
    Mar 2008
    Default Interact 1 MKII TNC 2500
    I have had one of these for several years for my home shop use. I had not run it in several months, maybe close to a year. I get a Gross Positioning Error Y C. I checked the motor cables, brushes, took the encoder apart and checked connections. Tried changing the voltage at parameter 1140. I decided to home Z and X and let Y warm up. In a few minutes I smell smoke and kill everything. A resistor is burned up and maybe the transformer on MT1-1 board. Probably repairable, but second time, different resistor. Another periodic problem is the KTK drive errors out if you try to run a high RPM, I have to step it up in the program. I am so sick of this stuff. Should I rip all the electrics off? I like the Heidenhain control and have a good programming system. The machine is extremely low hours and mechanically excellent.
    What to do????
    Jan 2005
    us
    Default Re: Interact 1 MKII TNC 2500
    If you let the smoke out of the drive card, then you need to have it repaired or get a replacement
    the KTK drives are a pain I hear, but if it works mostly....
    the control itself is pretty sturdy, but the attached electronics sound like they are letting you down
