You might have to replace the yoke to accommodate the diameter of the new nut. As I recall the housing for the original nut is a bit small for a ball nut.
I’m hobbyist and I need your support to convert a Brideport into a CNC milling at the lower cost possible.
First, I have to remove the backlash. Can I remove the old factory screw and replace it with cheap china ballnut?
Thanks,
Jeff
Jim Dawson
Sandy, Oregon, USA
Check out these guys. Very good people. https://www.machinerypartsdepot.com/
