Need Help! Tool change height incorrect. Bridgeport Interact 520 Vmc
Results 1 to 2 of 2
Thread: Tool change height incorrect. Bridgeport Interact 520 Vmc
    Registered wildblood7's Avatar
    Oct 2018
    Exclamation Tool change height incorrect. Bridgeport Interact 520 Vmc
    Hi, I have a Bridgeport interact 520 VMC with heidenhain TNC 155 control. I have various issues with the machine; Sticky limit switches, Buffer battery and parameters, dodgy Z axis encoder all of which have been overcome.
    I have written some basic programs and all the axis are operational as is the spindle.
    The problem I have now is the tool change height is incorrect. No matter what I change the parameter to the control indicates that the Z-axis has moved to 0.000 for the tool change. As it turns out I need the Z-axis to be at about -7.9mm to be at the correct height.
    I have set the positive Z limit to be ~+7mm and the tool change height to be -7.9 but the machine always goes to 0.000 regardless.
    Anybody experience a similar problem and know how to overcome it?
    Many thanks,
    WB
    May 2016
    United Kingdom
    Default Re: Tool change height incorrect. Bridgeport Interact 520 Vmc
    We would need to see your program
