converter recommendation for torq cut 22 - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 19 of 19
Thread: converter recommendation for torq cut 22
  1. #13
    Oct 2016
    Puerto Rico
    Default Re: converter recommendation for torq cut 22
    greetings I could not answer but I'm back the voltage in my house is 230v and configure both transformers to 230v and I could turn on the electrical panel without turning on the VFD or the spindler since they are 480v consult with those of Bptparts.com and I They said they were 480v
  2. #14
    Oct 2016
    Puerto Rico
    it's already on but I'm having a problem when I give the drive the enable it is giving me an alarm (Axis Drive Fault) that could be causing this failure
  3. #15
    Oct 2016
    Puerto Rico
    for the spindle and the VFD I will have to install a transformer 208 to 480v
  4. #16
    Gold Member
    Jan 2005
    Quote Originally Posted by christian7r View Post
    You need to connect your mains Power 230v supply to L1 and L2 then Jumper L1 to L3 this won't run you VFD drive because of the 480v needed but the rest of your machine should run, the transformer may cost a lot as well you may find a 230v VFD Drive that is cheaper, check to see what the spindle motor voltage is it may be 200v to 480v so just changing the VFD may work if the motor wiring can be changed
    Mactec54
  5. #17
    Oct 2016
    Puerto Rico
    I did that without connecting the VFD and since everything turned on the spindle motor says on the 400v board, I read something that the axis drive faul alarm is because the vfd is off so it does not let me enable the other drive
  6. #18
    Gold Member
    Jan 2005
    Turn the VFD Drive on then it won't hurt the VFD drive may give a low voltage alarm though this way you should be able to check the machine homing Etc.
    So if the spindle motor can't be changed for 240v, I don't know how you are going to get 480v 3 ph just for the spindle motor and Drive that will be quite a challenge
    Mactec54
  7. #19
    Oct 2016
    Puerto Rico
    ok thank
    I'm checking a step up transformer 208v to 480v
