Need Help! Bridgeport VMC600/22 buffer batteries
Results 1 to 3 of 3
Thread: Bridgeport VMC600/22 buffer batteries
    HugoLargo's Avatar
    Sep 2018
    Default Bridgeport VMC600/22 buffer batteries
    VMC600 is displaying a 'exchange buffer batteries' warning - for about 4 days.
    I understand these batteries are located in the 'gold' box by the main electrical supply panel.
    Am I right in thinking I have to momentarily cut the power in order to enter the panel then turn power back on before changing the batteries?
    Member cooperjm's Avatar
    Sep 2009
    Default Re: Bridgeport VMC600/22 buffer batteries
    Did you resolve your battery issue?
    What controller is on this machine?
    Jan 2005
    us
    I am late, but for future reference
    Assuming a Heidenhain control
    usually when the message first comes up, the batteries are low not dead.
    yes you need to shut the power off due to the interlocked door, otherwise you change the batteries with the power on.
    If you do not have your parameters backed up, do it now!
    So, open the door
    turn the power on by fooling the little lever on the power switch
    replace the batteries with the power on and you will not lose your programs and parameters
