This is one of the main problems of low encoder CPR, it happens to everyone that goes below a 14 Bit Encoder, this is around the lowest you can go the higher you go the better it gets 16 Bit ( 65536 CPR ) is the minimum I go on any build, anything below this is a waste, and of not much use for machining, over the last 10 year machine builder have realized this also and now most cnc machines that are built have 1 million CPR or more
