Wiring single phase motor to inverter
Results 1 to 9 of 9
Thread: Wiring single phase motor to inverter
    Dec 2013
    Default Re: Wiring single phase motor to inverter
    Your picture is not showing. Unless you have a special VFD designed for a single phase motor you can't connect a single phase motor to a VFD.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2003
    Also 1ph induction motors have a bad record when used on an appropriate VFD made for 1ph, they have been known to drop out of run at low rpm especially with a load.
    This is one reason why the 3ph is much more popular.
    Jan 2009
    sg
    i saw this link but not clear wiring 2 cable motor to UVW.
    My milling motor 1000w 3phase failed need to replace two choice by single phase motor or use stepper motor 86 12NM,
    i have tested this step motor by this control Pulse / PWM generator for stepper motor drivers - Hobby Components running well +DM860H
    what you think?
    - - - Updated - - -
    i saw this link https://www.youtube.com/watch?v=OaltPowJW08 but not clear wiring 2 cable motor to UVW.
    i have tested this step motor by this control http://hobbycomponents.com/motor-drivers/537-pulse-pwm-generator-for-stepper-motor-drivers running well +DM860H
    what you think?
    Dec 2003
    That motor is a simple shaded pole motor, you can also control them with a Triac controller, any other 1ph motor you would be lucky to get away with it with a VFD.
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by cornelis1 View Post
    what you think?
    There are some VFD drives that can run a single Phase motor, here is ( 1 ) I had on file, I have not looked at it, but it has single phase in and out
    Attached Thumbnails Attached Thumbnails Wiring single phase motor to inverter-sku721002-inverter-operation-instructions-1-4-pdf
    Mactec54
  7. #7
    Dec 2003
    The gamble is with 1ph motors on a VFD is to whether or how your 1ph motor will perform, even at all, this the VFD manuf. cannot guarantee, with a 3ph motor there is seldom the same concern.
    Jan 2009
    sg
    ist not recommend to use this way ?
    stepper 86 12NM+DM860H, with
    Wiring single phase motor to inverter-speed-reversible-control-simple-stepper-motor-controller
  9. #9
    Dec 2013
    If the stepper motor has enough speed for your milling, then yes, that will turn the motor. You might be able to see about 1200 RPM out of the motor, but probably less, but not much torque at that speed.
    Jim Dawson
    Sandy, Oregon, USA
