Build Thread Torq Cut 22 DX32 Floppy disk to USB
Results 1 to 6 of 6
Thread: Torq Cut 22 DX32 Floppy disk to USB
    Aug 2014
    Default Torq Cut 22 DX32 Floppy disk to USB
    Since I dont have a floppy drive in any of my computers I decided it was cheaper and easier to ditch the disks and use one of my thumb drives for transferring gcode. I picked up my Gotek emulator from Amazon prime for $30 but you can find them on ebay in the US for $20-25 shipped. Mine is labeled as a Gotek but I am sure just about all of them work well for this application.
    Video showing install and the emulator in action on a DX32 machine. Note: these two videos are not mine I am just referencing them to hopefully save the next guy some time.
    This video documents exactly how to format your USB into one hundred 1.44mb partitions. You can actually hold down both buttons and adjust the partition up to 999 but I have not tested it myself beyond 0 - 99.
    I suggest leaving the jumper as is on S1 or you can try S0 if your machine fails to recognize the device at bios boot. So far mine is working great for me and switching between partitions is as easy as the push of a button and re-entering the A: drive assuming your jumper ends up being default. I plan to have two thumb drives both with partitions dedicated to backing up my machines configurationnand storing copies of DOS and DX32.
    Attached Thumbnails Attached Thumbnails Torq Cut 22 DX32 Floppy disk to USB-20161217_004820-jpg   Torq Cut 22 DX32 Floppy disk to USB-20161216_181040-jpg   Torq Cut 22 DX32 Floppy disk to USB-20161216_233550-jpg
    Aug 2014
    Default Re: Torq Cut 22 DX32 Floppy disk to USB
    ipcas - USB Floppy Emulator V2
    Link to the software needed for partitioning, reading and writing files to your thumb drive. The site was down when I first setup the emulator so if you have trouble accessing it let me know so I can post the v1.40i zip file.
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by hax0red View Post
    Excellent work in doing this conversion
    Mactec54
    Jan 2010
    Has anyone got one of these working lately? I've tried several jumper positions on the one I bought (FAT32 Drive Emulator, SFR1M44-U100), and I get the same "Seek Error Reading Drive A" error. If you have one working can you provide the model # you're using and the jumper settings?
    thanks,
    Jim
    May 2009
    jdub63 Did you ever get it going?
    Jan 2010
    No, I ended up ditching the entire control system. I’m converting it to a centroid oak controller Torq Cut 22 DX32 Floppy disk to USB-4b5169ed-ad71-4747-9574-9793101fa65f-jpg
