Bridgeport Torq-Cut TC-3 adding a 4th axis
Results 1 to 4 of 4
Thread: Bridgeport Torq-Cut TC-3 adding a 4th axis
    Dec 2005
    Default Bridgeport Torq-Cut TC-3 adding a 4th axis
    My understanding is that the DX-32 control is 4th axis capable. I know I can pulse an indexer. What I'm wondering is how I can add a true 4th (A) axis. I have a spare control so I should be able to harvest the servo drive and wiring and add it to my machine. I then would need an appropriate DC servo drive indexer of course. Has anyone added a 4th axis to their Torq-cut?
    Sep 2017
    Default Re: Bridgeport Torq-Cut TC-3 adding a 4th axis
    I’d like to know this too were about to acquire one although the price is reasonable enough I figured we could retrofit worse case scenario. Did you ever find out?
    Dec 2005
    I never did. My understanding some came 4th axis ready with the wiring harness already in place. Mine didn't. I'm still interested.
    May 2009
    Quote Originally Posted by forhire View Post
    My 22 came wired and with a 4th axis. From what I understand the x axis drive card was damaged and they pulled the A drive card and switched it to X. I have not had time to really test this out but I did find some loose caps on the damaged card and last week replaced them. I figure I'll move the repaired drive card back to X and see if it works and is stable. If so then I'll plug the A drive into the machine and see if I can jog it around. The former owner said it did work and they sometimes used it for parts making in their shop.
