You will need to do more than connect to the 230vac line correctly. You will have to configure the vfd to safely operate your spindle. Each vfd is different so you need the manual to connect and set it up correctly.
Here is a link to the operator manual. You may need to search out a programming manual also but this will get you pointed in the right direction.
http://www.inverterdrive.com/file/AB...l/default.aspx
