There is a BPT technical bulletin on communications to a TNC control. I have to find it.
Just in case it exceeds the 500 KB limit here, what is your email?
George
can anybody tell me how to and is it possible to dripfeed long programs to a tnc151 control?
George
I found technical bulletin 6. It is about 2.5 MB long.
George
thanx machintek.
Done. See if this helps.
Heidenhain can also be called. They are just outside of Chicago.
George
machintek
Do you think I could get a copy of this bulletin also?
Thanks Tony
Download TNC REMO from Heidenhain's site - set it up and run TNCSERVEROriginally Posted by DustyL
Make up a cable from 25way TNC151B to 9 way PC as follows:
(25way TNC) <9 way PC>
(2) - <2>
(3) - <3>
(4) - <8>
(5) - <7>
(6) - <4>
(7) - <5>
(20) - <6>
The TNC RS232 interface can exist in three modes - "EXT", "ME", and "FE" selected via the 'MOD' key - it should be in "FE"
File names & extensions ARE important in block mode transmission. 123.H = program 123 in Heidenhain conversational code and 123.I is program 123 in ISO-Gcode
When set up like the above it will work - it took me ages to sort it but now all is reliable.
AWEM
Andrew Mawson
East Sussex, UK
Tony, if you still need this tech bulletin, give me an email address.
George
machintek, sorry about that. It's tonykutscher@optonline.net
George,
Could you send me a copy of the tech note. Now that the mill is up and running it is time to get it connected.
My e-mail is paul(dot)jeran(at)hp(dot)com
Thanks,
Paul
Tech Bulletin 6 sent to both of you.
George
Hi, where can I get that manual?
Greetings
George,
Do you still have this? Can you send it to me?
