- Plz Help! Wavy line issue on new boss laser
Wondering if anyone has some troubleshooting ideas with this issue I am having. I will try and lay out my setup and what I have tried so far. If I am missing anything, please let me know so I can add it.
Setup:
Boss Laser HP 5598
Running lightburn
Tried cut speeds ranging from 10mm/s to 350mm/s, same result.
Tried reducing acceleration in X and Y from 2000 to 200mm/s2 and 3000 to 300mm/s2, same result.
Motion Parameter Settings image attached along with the issue in question.
Belt tension:
Both Y axis belts seem extremely tight. X axis belt seems looser compared to Y axis but still decently tight. - Wasn't going to try and tighten unless yall think that may be my problem?
- You may not post replies
- You may not edit your posts
Forum Rules
