Originally Posted by
jram
You'll be really happy with the 2436, I just received the exact model with a 100 watt tube and it's a great machine! We also got a ls1416 with a 60 watt tube and have yet to get it hooked up will soon have the two running together. One thing that may help you. The easiest way we found to get it out of the crate was to make a ramp with one of the crate sides once you have them off. We placed a few chunks of wood and 4x4 under the plywood for support and it rolled right out.One other tip that I wish I would have known right away is to reset your focal depth. It takes about 3 minutes and is done in your software, it makes a huge difference! They will send you a PDF on how to do this.
