Originally Posted by
TacPen
Alright, I guess I'll chime in. We bought our BOSS Laser LS-1416 w/ 60 watt in December of last year. The pre-sales service was very good (Kevin was the guy). The purchasing experience was a bit of a pain but I believe they cut us a fair deal and part of it was that we changed our order mid-stream, otherwise no issues here. The laser itself was well shipped and very well packaged. We started hooking it up and tried using it immediately. Now, the build quality of the case was not impressive. A few things didn't line up perfectly but it wasn't bad, especially for the money.
Here's what did bother me, the laser was supposedly tested at their shop but when we received it there was a cable improperly routed and in the way of the beam so the laser could NOT have worked. Easy fix but I found this disappointing... not a deal breaker but it did erode my confidence in BOSS. The Engrave Lab software is very quirky and I don't like it, but it does work. The quality of the actual beam for cutting and engraving is very good. No complaints at all, it works on everything up to and including stainless and titanium. Very impressive.
Our experience with support has been fairly positive although the videos and instructions are sorely lacking. It's definitely a DIY type of thing. We also got hosed on the rotary. Because of the small bed size on our machine it's utterly worthless. The guy who tried walking us through hooking it up also had no idea what he was doing and blamed us for not doing it right... until he realized that he had a different model laser. He then told us he didn't have the same model in the shop and we were out of luck. I found this to be disappointing (actually called them and complained). We also have NOT been able to get this laser to work with Corel Draw at all and have not gotten any help from Boss on this. I understand that this is not an issue with the laser but we were told that it would work before we bought it.
My other frustration is the non-fixed engraving surface and nothing lines up within the machine. It's easy to work around but you have to make your own fixtures everything if you want any repeatability. Not a huge deal but a bit of a pain. The ULS, Trotec and Epilog engraving platforms are much better.
Overall, this is an adequate lower-end machine for the DIY type but it's just not a production quality machine and the support is just not there for me to bet my business on it.
Would I buy it again? No, I would spend the 3x - 4x to get an Epilog or ULS. If it was a money thing, I'd probably just buy a used one. The interface and support from the big guys is just better (although you DO pay for it). I do think this is a workable machine and we are using it to laser high quality engraving and cut acrylic displays. For someone that is on a budget who is willing to put up with the niggles, it might be a good start.
For us as a business tool, the frustration and time spent are not quite worth the savings but I can see that for others it might be.
