- unlock code for BOSCH CNC CC220
Does somebody knows the code for unlocking parameters memmory of BOSCH
CNC C220. Also what means error mеssage NC-FEHLER 2665?
Try this:
468 SAVE DATA
355 Permanent protection ?
377 EPROM I/O
252 SERVICE
438 DELETE ALL TABLES
630 DELETE ALL MEMORY =>RELOAD
339 SERVICE FUNCTION (PIC / PLC)
340 EDIT PROGRAM (CLP)
683 Variable Edit
377 LIBRARY LOCK/UNLOCK
Thank you
Thank you very much. That is just what I need. You are great man.
HELP WITH BOSCH CC220
Hi ,
i have the same controller bosch cc220, please send me how to activate backup (error code 277).
kris
Try this:
468 SAVE DATA
377 EPROM I/O
252 SERVICE
683 Variable Edit
m/c status bosch cc220
I have the same control bosch cc220 do you know whats mean status 20 and status 19.
In my manuals only I read "errors" and "troubleshooting" but status not.
Do you have a list of status
Hi
Need help!
Have the same problem like DIMITAR. We have Balstfulland CNC 1000 with BOSCH CC300M controler with 4 axes.The batery 3,6V on MEM3 modul was empty and all data and files lost. We change the batery but all files are lost.Don't know what to do to get it up and running again because control CC300M is in somekind stop mode(READY 2 line on PS 100 is OFF). If anyone have the procedure for get it up please send me. If someone have backup of all files for this type of machine please send me. I have the PC communication software and cable for transfer the files to CC300M. Also have a lot of manuals and documentation for BOSCH CCxxx controlers if someone need.
My e-mail: tzvonko@hotmail.com
Bosch CC300
Did U solve the problem yet?
contact me : karmoleed at yahoo dot com
Good Luck
ERROL 2670
hello ........JIM FROM GREECE
i have one CC 220 BOSCH
first I had problems with error 277
I change all the batteries (three batteries) and i made reload....377
1- AUS EEPROM
2 - inter password 377
3- wait one Minute
4- the soft key Rest will appear
5-select RESET......
AND RELOAD 281 FROM EPROM
Now I have the error 2670
-NC-FAULT 2670 - SPS TIME INHIBIT
- PANEL FAULT- CLOCK POWER FAIL.
AND THE READY 2 NOT LIT IN THE POWER SUPPLY...PS 100
WE HAVE THE SAME ERROR...2670
DO YOU HAVE SOLUTION TO ERROR ???
f you have something to recommend me
error 277
HELLO EVERYONE,
I AM MOM FROM PAL
I HAVE CC220 BOSCH AND THERE IS AN PROBLEM , CNC MACHINE NOT WORK
CC220 - fehler 277 - help
When I turn on machine, 24V light green, but no noise of cooler and on screen I can see:
EPROM TEST .... some numbers
CHECKSUM-TEST ... ERROR
MEMORY CLEAR
MPP
SYSTEM INIT
P2INIT
BACKUP LADEN AKTIV
BACKUP LADEN ENDE
on screen is:
FRAN EPROM FRAN EEPROM OMLADDING SERVICE FUNCTION
but nothing can be pressed.
and it stop on FEHLER 277
EDIT: now i continue to 2665 Spaenningsfall
Re: ERROL 2670
Hi Guys
We also are have a problem with our Trumpf 240 regarding the error 2670 - PC Time Inhibit.
Please can anyone advise how to handle this one?
Desperate!!
pass for BOSCH CNC CC220
hi i need the [pass] to copy a program 99990995 of manage EEprom
thank
Re: unlock code for BOSCH CNC CC220
Hello i have problems in cc300control no appears WAIT a press star bouttom , but in PLC the LED is ON
Thank
Hello,I have problem with BOSCH CC300,PANEL STATUS..... NO DATA TRANSFER TO NC INTERFACE.... PANEL TRANSMITTER LINE FAULTY.
Hello,
we have a problem with trumptc260R controller Bosch CC220
we need to reload program fro EEPROM, and it keeps asking me for password.
we tried 377,303 bu not working. any ideas?
Regards
Re: ERROL 2670
Hi Belios,
I know time has passed.
Were you able to correct Error 2670?
How did you do it?
Try to load from EPROM with password 281
Re: CC220 - fehler 277 - help
can someone help me with the error on power on (12 NULLP, ACHSEN/MAGAZZIN) on cnc gloria, with BOSCH c200 controller, from a vertical center
and guide me how to do tool magazin in home position
- You may not post replies
- You may not edit your posts
Forum Rules
