- Need help for BOSCH CC220
I am new to this Forum. I have a 5 axis milling machine using the BOSCH cc220 controller. I cannot start the CNC . The power Off button is lighted but there is no response when I pressed the power ON button.
The PC console show no error message and I have reloaded the memory from the EEprom. I have checked the wiring, changed the I/O cards but still I cannot start the CNC process.
I need help., thank you.
Re: Need help for BOSCH CC220
Check the emergency button, maybe it is pressed. You sometimes need to turn the button to release it!
- You may not post replies
- You may not edit your posts
Forum Rules
