- Trumpf punch with Bosch controller
Hello all,
I have a problem with a Trumpf Trumatic 200 from 1994. The machine has sat for over a year and now after turning on I replaced de batteries , one 4.5 v for the RAM and the other 3.6v in the power supply. The problem is that the error CP/MEM-BATTERIE dosen t go away and also NC FAult 2685 witch has something to do with linktables. If the machine sits for a couple of hours turned off then at start up it requests to reload the machine program procedure: Aus Eprom ..., Password.
I have no real experience with this controller , any advice will be appreciated .
Re: Trumpf punch with Bosch controller
the machine has at least three batteries, did you replaced them all?
Hi there
We have a Trumpf 500 however we have a fault come up saying no fault 2685
Cp men battery low but these have been changed
Where is the third battery on this machine as we have only found 2
Any help would be highly appreciated
Cheers
Joe
- You may not post replies
- You may not edit your posts
Forum Rules
