Bosch CC200
Results 1 to 3 of 3
Thread: Bosch CC200
    Registered alanser's Avatar
    Jan 2008
    Laufeld
    Does anybody know this error message?
    NC-error 2670
    SPS time out
    Kind regards
    Axel
    Registered alexejmedion's Avatar
    Feb 2009
    Offenburg
    I have a similar problem with the Bosch CC 300 M Wanderer. Does anybody know the solution???
    Member makinnen's Avatar
    Jul 2012
    Quote Originally Posted by alanser View Post
    NC-error 2670
    SPS time out
    Kind regards
    Axel
    Hey Alex, NC error 2670 (PC TIME BARRIER) Could be different things....What machine are you using with this controller?
    Causes may be:
    1. Check if SPS is running
    2. Is switch Edit/Monitor on RAM Board in Monitor position?
    3. Battery power loss could also be the case.. Check all your batteries
    4. Did you check your connection cables? between NC and SPS?
    5. Is the Ausg. Sperren (Clear Output) switch on the ZE Board in the UP position?
    Let me know if after this you still have the problem..
    Regards..
    Mak
Bosch  CC200
Bosch  CC200
