Matec 30 HV Bosch OSA3
Results 1 to 6 of 6
Thread: Matec 30 HV Bosch OSA3
    Registered Sit22's Avatar
    Oct 2005
    Gera
    Hello people
    Is anybody familiar with Matec 30 HV Bosch OSA3?
    I have to write a PP for this machine. The machine has two separate workflows.
    It has AB axis on the left and BC axis on the right side as swivel axes.
    What about swivel cycles? Does the OAS4 controller have anything like this?
    If it has, what do they look like?
    I haven’t managed to found a programming instruction. Does anybody know a link?
    Greetings
    Sit22
    Der Meister's Avatar
    Sep 2003
    NRW
    Hello people
    Greetings
    Sit22
    Hello Sit22
    I’ve got a pdf… “Operating manual Matec 30 L / S / LD / SD / HV”
    Maybe it would help!
    Greetings
    Debugging? Klingonen debuggen nicht. <br>Unsere Software ist nicht dazu gedacht, <br>die Schwachen zu verhätscheln.
    Edeck's Avatar
    Mar 2008
    Why don't’ you contact the manufacturer?
    Registered Reaper26's Avatar
    Jul 2012
    Timisoara
    Quote Originally Posted by Sit22 View Post
    Hello people
    Greetings
    Sit22
    Jul 2012
    Timisoara
    Hello,
    Can you send me please a pdf with informations about Matec 30 L ?
    shtelica123's Avatar
    Feb 2017
    cluj
    Hello,
    I have a machine Matec 30 HV with Bosch Rexroth cnc controlled.
    I want programming by the parameters but I dont know who to write.
    I write for example @200=10 and give some error for syntax. I try with #201=10 and the same error from syntax.
    Thank you
