I have a BODOR laser with tube RECI 90W. I have this problem for a while.
Laser has no power up to 30%, and starts to lower above 60%. I changed the power supply, but this didn't help, problem stays. At 20 % current meter shows 4 mA, at 50% - 12 mA, at 95% - 26 mA.
They tell me it might be a problem with the tube. It worked only 100 hours but it's 6 years old.
I will attach a picture with a test I made using different percentage power at 10 mm/s speed, so you see what I mean, if I was not good enough in explanation.
Did anyone had a problem like this. What do you think is the tube the problem, or there might be another reason?
I would really appreciate your help.
