Bodor fiber laser cutting machine combines size and smart
Results 1 to 1 of 1
Thread: Bodor fiber laser cutting machine combines size and smart
    Member juliusxiong's Avatar
    Jan 2020
    Default Bodor fiber laser cutting machine combines size and smart
    Bodor S series fiber laser cutting machines offer a maximum 8100mm*2500mm large format and multiple smart control features.
    Bodor fiber laser cutting machine combines size and smart-bodor-s-series-fiber-laser-cutting-machine
    To fulfill users’ needs to cut large-size and thick metal sheets, Bodor introduces S series fiber laser cutting machines. Among all the models of S series, S8025 has the largest 8100mm*2500mm format, giving users the most desirable operating room and flexibility. And S series models can offer a maximum 30KW laser source, which is able to cut 130mm stainless steel and 70mm carbon steel.
    Apart from size and strength, the smart control features on S series are also worth talking about. With 360° radar system, obstacles can be foreseen, and Z axis will be automatically enabled to help laser head avoid the obstacle swiftly, lowering the chance of collision. Bodor also applies closed-loop gas pressure control to stabilize cutting quality. By monitoring real-time gas pressure, automatic pressure adjustments will be made according to the difference compared to theoretical value.
    As for cutting process, Bodor Cutting 3.0 technology can help users improve efficiency as much as possible. Firstly, when 20KW laser source is used to cut 16mm carbon steel, Oxygen Fast Cutting can increase efficiency by 37%. And when 20KW laser source is used to cut 20mm stainless steel, Low-pressure Nitrogen Cutting can increase efficiency by 23%.
    Attached Thumbnails Attached Thumbnails Bodor fiber laser cutting machine combines size and smart-bodor-s-series-fiber-laser-cutting-machine
