bodor x1006 39x24 inch bed 150 watt 5200 water cooler
Results 1 to 3 of 3
Thread: bodor x1006 39x24 inch bed 150 watt 5200 water cooler
    Member woodman08's Avatar
    Oct 2007
    canada
    Default bodor x1006 39x24 inch bed 150 watt 5200 water cooler
    looking for ideas of what could be wrong , as the laser tube is not firing:
    --all power supplies are running , green led's showing green, laser tube
    power supply fan is running looks ok
    --checked the lid switch which has an led
    --I bypassed the cooler cw 5200 outlet filter thinking it was restricting the flow
    it did not make any difference
    --I cleaned the cooler filters which were clean
    --i changed the usb cable to the computer made no difference
    -- When the usb is connected to the computer the laser moves very slowly and noisy like its in low gear
    --pushed the system reset front power voltage 1 reads 4.89volts
    --laser runs smooth with no computer hooked up via usb
    --computer will not communicate with the laser says it fails, when i try to download or read settings from the laser
    --my controller is RDC6442S-B (EC)
    --diagnostics off the small screen does nothing
    -everything was running fine until the 48v ower supply failed
    machine alarm says machine protected
    I cannot seem to think of any other permissive to stop the tube firing
    any ideas would be welcome, as I seem to be on my own
    Attached Thumbnails Attached Thumbnails bodor x1006 39x24 inch bed 150 watt 5200 water cooler-dscf8926-jpg   bodor x1006 39x24 inch bed 150 watt 5200 water cooler-dscf7280-jpg
    Oct 2007
    canada
    Default Re: bodor x1006 39x24 inch bed 150 watt 5200 water cooler
    turns out it was a bad relay and controller board has a fault...bodor treats people very badly
    they have no respect for customers
    its well built but take your chances when you need help
    Oct 2007
    canada
    Bodor promptly shipped me a new 2020 controller and I installed it today and its working good
    It was a quick turnaround to get it shipped
    appreciate the quick help
