Are there any updates to the turning?
The new BobCAM for SOLIDWORKS™ Gold Partner CAM solution lets youprogram powerful toolpath operations for part models right inside ofSOLIDWORKS™. Built as a SOLIDWORKS™ plug-in product, BobCAM offers all ofthe benefits of a modular CAM product with an improved workflow and accessto over 30 simple & advanced toolpaths that provide the efficiency needed tocut high quality parts quickly. Industry applications range from automotive toaerospace, medical, military, general fabrication, and much more! BobCAM’s high efficiency wizard driven interface removes the guesswork from toolpath creation and g-code programming and streamlines the process of cutting parts. It allows you to spend less time programming and more time producing. From routine to complex parts, BobCAM for SOLIDWORKS™ is both a powerful CAM solution that’s easy to use and the most affordable SOLIDWORKS™ CAM add-on of its kind.
http://bobcad.com/pdf/v5/V5_bobcam_Brochure.pdf
- Need Help!- One CNC Vs BobCAm
- BobCAM V4
- Solved BobCAM vs. V27
- Newbie- New to bobcam
- Need Help!- bobcam v12.5.2
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
