I'm not sure about that but you can load these -
CamBam Stick Fonts
into Windows
I have both Bodcad V24 and V2 for solidworks. My question is this. There is a Bobcad font within V24 and it is a single line font. Is there a way to load this font into window to be used in solidworks?
- Font Help
- how do i add a font???
- Newbie- What font?
- Problem- bobcad/cam machining font
CamBam Stick Fonts
into Windows
idk about loading fonts into solidworks but If you are looking for a stick font in solidworks.
go to SKETCH TEXT. uncheck USE DOCUMENT FONT, click FONT.
Select OLF SIMPLE SANS (the letters look a little weird in the dropdown box, but it is the one you want), type the text you want, attach text to curve or line, click ok
From there you just explode the text, then you can select the geometry in the Engraving toolpath screen.
I hope this helps.....
