MillPst file for Centroid Acorn for V23
Results 1 to 5 of 5
Thread: MillPst file for Centroid Acorn for V23
    Oct 2012
    Default MillPst file for Centroid Acorn for V23
    Looking for a MillPst file for Centroid Acorn for V23, or one that will work.
    There used to me many more machines available. When I try to run MillingMachineSetup.exe I get this error. I can run EDM or Lathe no issue. I reran the installer and fixed issues but no luck.
    I have a Robotool with Acorn control now. I used to see Robotool as an machine option but no longer, not that that matters.
    Attached Thumbnails Attached Thumbnails MillPst file for Centroid Acorn for V23-bobcad-millspst-jpg   MillPst file for Centroid Acorn for V23-millingmachinesetup-jpg
    Member machinehop5's Avatar
    Aug 2009
    Default Re: MillPst file for Centroid Acorn for V23
    ...try looking in a different Directory
    MillPst file for Centroid Acorn for V23-bobcad-millpost-jpg
    Oct 2012
    Quote Originally Posted by machinehop5 View Post
    That is the directory I am in. The file won't run. Has error as shown.
    Aug 2009
    Quote Originally Posted by geckocycles View Post
    ...try adding this File to that same Dir
    Attached Files Attached Files
    Oct 2012
    Thanks. That one didn't work. Extracted it directly into root dir. I did find one that did out of the six I have found. I don't see as many machines and no Centroid. MillingMachineSetup.exe runs now so it is probably workable. See what I can do.
    garpk's Avatar
    Dec 2021
    Looking for a Robotool Master Disk. Anyone willing to share the file? Gary
