Does the post processor actually create the values X 10.000”, Y 0.200” in the code?
Need some help please. G-code generated by the post processor I have will not cut a straight line from point A to point B. For example, if a line is programmed to start at point A (X 0.000”, Y 0.000”) and travel to point B (X 10.000”, Y 0.000”) the resulting line will be skewed off by some amount. The resulting line may give a point ending at C (X 10.000”, Y 0.200”). This error occurs in both X and Y directions of travel with unpredictable outcomes. Talked with folks at Bobcad,but they say it will take 2-4 weeks to modify a post for me.
Anyone have a post they can share?
I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
Are you using cutter comp? You have to have a lead in.
Sent from my SM-N960U using Tapatalk
Also i have a post processor for bobcad v30
