Need Help! Top of part value in PP?
Results 1 to 4 of 4
Thread: Top of part value in PP?
    Feb 2013
    United Kingdom
    Default Top of part value in PP?
    I've tried part_height but that just yields zero all the time, I know that reference_plane is equal to Top of Part + Rapid Plane, I can live with a set Rapid Plane value if a hard coded subtraction can then be done in the PP to yield Top of Part, but none of my guesses at syntax have worked.
    Any ideas gents?
    TIA,
    Nick
    I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
    Feb 2013
    United Kingdom
    Default Re: Top of part value in PP?
    I've sorted out Advanced Posting for BCC V25 through to V29 so I'm just adding a tab to the drilling wizard with an input box allowing me to pass Top of Part directly to the VbScript in the PP
    No posers SBC Cycle's Avatar
    Apr 2008
    I was digging around today in the documentation for V31 and stumbled upon this API call today.
    MILL_Get_TopOfPart() – API Only
    Mill Job
    Returns the top of feature value for the current feature.
    I haven't tried it but it looks promising. Trouble is I don't know what version this API call is valid for. But thought it was worth mentioning!
    Mastercam X9/2018 Multiaxis for SolidWorks - Bobcad V21-V30 3ax Pro 4ax Std.
    Feb 2013
    United Kingdom
    Thanks for that!
    I'll see what that yields in V25 when I next delve into the PP
    Regards,
    Nick
