Need Help! Mazak M2
Results 1 to 2 of 2
Thread: Mazak M2
    *Registered User* drummondracecars's Avatar
    Jan 2019
    Default Mazak M2
    Does Bobcad have a post processor to work with a M2 control on a 4 axis mill ? Also do they offer the comunications cable to do this ?
    Registered The Engine Guy's Avatar
    Jun 2008
    UK
    Default Re: Mazak M2
    What Post Procesor are you currently using??
    Attached is the latest Mazatrol M2 PP, it is configured to use an "A" axis rotary 4th axis.
    BobCAD-CAM does not have a built in DNC for uploading or drip feeding to the Mazatrol control, you would need either the Predator Level 2 that you may have depending on the version of BobCAD you have, or another sofware like "Easy DNC" for example.
    Hope this helps
    Regards
    Rob
    Attached Files Attached Files
Mazak M2
Mazak M2
