Update! I guess there was a bit more that my predecessor was putting in manually in a text editor after every post. :/
I plan on updating this to remove redundancy in some values, such as setting the Z axis in every block, even though it's not changing. I also want to run WinXISO at the end of post to convert this to a PGM, so I don't have to do it on the mill controller after I post.
If anyone has questions or comments, I'd be more than happy to help. Hopefully someone gets some use from this.
Changes:
03-02-2018 - Added SY=1 M=0 to File header.
03-06-2018 - Added X0 Y=-stock_length to header. This offsets
the Y axis by the length of the material.
I also altered the ending X coord so as to move
the work head away from the material
automatically.
Ugh! I jumped the gun a bit. X0 is supposed to be XO, and upon request, I changed the commands for boring, BO, to B. BO is optimized boring, and B is simply unoptimized boring, I guess. I'm pretty new to this. Here's an updated millpst.
I changed some formatting of the changelog in the millpst to make finding corrections a bit easier, as well.
- Changed X0 to XO, above. My bad. - Block 0.
- Changed instances of "BO" - optimized boring, to
"B" - unoptimized boring. - Blocks 800 to 831.
Reason: Had debug turned on :<
New update. Lots of changes to this. I'm not entirely sure how the CAD/CAM process went before, but now since I've started developing on my own, I'm developing everything in quadrant 1 (x+/y+). I've altered how drilling works, since it's not using optimized boring anymore. Here's a quick changelog. It's far from a complete changelog though. I have a hard time documenting things as I change them. So far this works flawlessly for me. No more changing offsets at the head.
04-30-2018 - Removed XO which was the origin change command. It's
not necessary if you're developing in quadrant 1.
(x+,y+) - Block 0
05-01-2018 - Added code to Block 50 for rapid movement.
05-02-2018 - Removed 'work_coords' from the file, as it didn't
seem to be doing anything useful.
- Edited the boring commands (Blocks 81-99) to remove
N="L", since that's only used in optimized boring.
- Created Program Block 9, to properly set the drilling
z depth. It was negative before which wasn't working.
Applied Program Block 9 to be used in boring blocks
81-99.
- Added rotational speed and velocity to boring commands
in blocks 81-99
- Other small changes, like formatting cleanup.
