In earlier versions you could break a line and place a point at the end of the segment on the break, you could then choose the points as tab positions
I cant see why that shouldn't work in later versions
Is there any way to add tabs to points besides the beginning, middle or end of a line? I really need to be able to position tabs in specific places so that when I'm machining the part next to it the tab doesn't get removed by that toolpath. I'm using V34.
Thanks!
Mike
I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
