Do you mean this surface?
for the life of me i cant seem to repair the missing surface on this modal any help would be great
thank you
Barrie @ Composite Specialities Ltd. using BobCAD V30 Mill 3 axis Pro, Bricscad V14 and MOI V3 with CNC-Step High Z 1000S and Wabeco CC-F1210
yes sir.
OK, that surface was created from wires that you had already placed in the model.
It is a 4 sided patch using the two long horizontal lines including the big radius and then the two vertical lines.
Does that help?
B.
