I have updated my issue. I would really like to figure out this problem. Just for the sake of solving it. It's only on this part that I having the problem.
I attached a small 1" fixture, and set my indexes on that fixture assuming that it was an ucs or index problem with the 4 axis. Still, the toolpath looks to be .25 above part, and a definite arc that has nothing to do with my solid. when I compute. It never touches part. I moved model to another 4 axis setup that I have no problem milling parts with. I have attached a new file under the new routine.
This is a puzzle that I am not getting anywhere with. I have other parts that I use this same routine, no problem. The 4 axis toolpath is tight to the part. But this one is not working. So, is it a problem with ucs, index, part creation, or do I need to upgrade to pro ?
So if you like bobcad puzzles. Look at the file I have uploaded to google drive
https://drive.google.com/file/d/1F3Q...ew?usp=sharing
Thanks, Any help would be appreciated.
JC
you can also call me or DM at 304 994 2976
Also, anyone working with bobcad in the southern west virginia, or lower virginia / roanoke, blacksburg, that would like to meet up. DM or call me.
