- Need Help!- Twist
Twist
Hi Guys. I am trying to extrude a screw twist. Can someone give me any pointers please.
Ghost
Re: Twist
In BobCad, you'll have to generate the upper and lower "spirals" and also the root spiral, then use a skin command...
Manually building it. there wont be a "sweep profile" command to spit that out in 1 go...
Ghost
Re: Twist
Sorry, my bad. That was for "Bolt threads".
For a "Screw", much simpler.
Make a helix of ypour screw. Put a single straight line down the middle of the helix center. "Cross section" the helix and the pole.
- Need Help!- Twist
- You may not post replies
- You may not edit your posts
Forum Rules
