Need Help! STEP file
Results 1 to 9 of 9
Thread: STEP file
    Jun 2011
    united states
    Default STEP file
    Hey guys hope someone can help with this
    Been a while since i used bobcad but i imported a STEP file and need to get it on the right view and make it a dxf so that my other software can read it. I can get it to the right view but after that no mater what i try i cant get it to select anything . i just need the outside perimeter of the the drawing. I dont need the 3d but only a 2d and saved to dxf and i cant get it to work. any help will be appreciated .
    Feb 2009
    Default Re: STEP file
    what ver BC?
    you have tried extract edges?
    David L. Aery
    www.hooksolutions.com
    Jun 2011
    united states
    v27 and no i havent couldnt figure out how to do that.
    Feb 2009
    go to Utilities, to Extract Edges, to single, then select your surface, click ok. now you need to hide your stp file and then your lines will show up. and then save as dxf, hope that works.
    David L. Aery
    Jun 2011
    united states
    so i opened it up got the view i wanted and went to utilites then a box with project to z came on . selected my surface hit ok and then went over to the cad and hit hide and nothing is showing up at all.
    Feb 2009
    when you do the hide are you point and click to select to hide or drawing a window around what you are hiding?. if you are using the window, then that will hide the extracted lines also.
    David L. Aery
  7. #7
    Jun 2011
    united states
    so i need to save it in the right view as a dxf i dont get how to do that . I am looking at the right view and when i save it as a dxf it gives me a top or bottom view.
  8. #8
    Feb 2009
    sounds like you need to use the USC or if I was doing this I would use Translate or rotate to get the view i want in the top view of the workspace., then I think you extract would work.
    David L. Aery
  9. #9
    Feb 2009
    i sent you a private message
    David L. Aery
STEP file
STEP file
