G code to cut inside groove
Results 1 to 4 of 4
Thread: G code to cut inside groove
    Mar 2006
    Default G code to cut inside groove
    I am using BobCam to cut an inside grove in a steel 1/4 inch hole. My tool is a 1/4 in. shank and cutter with 3/16 shaft. The groove need be only .01 deep. The posted code starts the cutter -.0075 in X and 0 in Y. If BobCad cant stat the X and Y at zero it is a no go. I do not write G Code so correcting this is beyond me.
    Nov 2013
    Default Re: G code to cut inside groove
    I'm not at all familiar with Bobcam however most CAM programs offer a thread milling toolpath.
    In that circumstance the Gcode lowers the tool into the hole on center and then move outward radially to start the groove.
    In a thread the groove is a helical path, but as you want a straight groove then nominate the 'pitch' of your 'thread' to be zero.
    The CAM should handle how the get the tool in and out of the hole thereafter.
    Craig
    Mar 2006
    Craig
    I didn't think of that. Of course. Thanks
    Tom
    Member GCSRT's Avatar
    Sep 2020
    Seems like you need to set your lead in/lead out correctly. Also dropping into a 1/4 hole with a 1/4 cutter makes it more difficult to get a nice ramping in ramping out.
