Need Help! custom tool
Results 1 to 3 of 3
Thread: custom tool
    Feb 2009
    Default custom tool
    I know I posted in here about a custom endmill, one with a 1/8" shaft and 1/16" cutter ball end, but can't find it.
    I have created one and i get an error message.
    i wanted to find the post that I read about and see if I missed a step.
    Attached Thumbnails Attached Thumbnails custom tool-error-tool-setup-jpg   custom tool-error-tool-jpg
    David L. Aery
    www.hooksolutions.com
    Oct 2006
    Default Re: custom tool
    That line going up the middle of the tool looks suspicious. The error message you received usually occurs when the assigned tool geometry can't be modeled in the simulation. Remember, solid lines for cutting edges and dotted lines for non-cutting edges like shanks and cutter bodies.
    Hope this helps
    Feb 2009
    Quote Originally Posted by bishb25 View Post
    Hope this helps
    Thanks!
    I missed the dotted line thing, changed the drawing and now that part looks right.
    Finally got it. The video was very helpful.
    This also showed, (which I already knew,) that this tool would not work in the cavity I was cutting, the larger diameter shaft would rub on the side, but now the simulation verifies that.
    Thanks again!
    Attached Thumbnails Attached Thumbnails custom tool-tool-setup2-jpg
    David L. Aery
custom tool
custom tool
