Need Help! BobCAD EXTENDED BOUNDARY HELP
Results 1 to 2 of 2
Thread: BobCAD EXTENDED BOUNDARY HELP
    Member robscholl23's Avatar
    Dec 2020
    Default BobCAD EXTENDED BOUNDARY HELP
    I was wondering if anyone would be able to help me out with this problem I am having 3axis milling using Bobcad V27. I attached an image for your reference, the face that is in question is the one i marked, I was curious if there was a way to extend the boundary/geometry for this application because how it is now the end mill does not go past the edge of the face so it leaves a little step on the bottom edge off the part, any thing helps i appreciate it!
    Attached Thumbnails Attached Thumbnails BobCAD EXTENDED BOUNDARY HELP-bobcad-jpg
    Member aldepoalo's Avatar
    Mar 2012
    Default Re: BobCAD EXTENDED BOUNDARY HELP
    1) save the file as a new file name, this way any changes you make do not effect the original file.
    2) Extract edges for the top surface of the blade.
    3) Create a UCS that aligns to the geometry
    4) create an offset profile of the surface boundary for how much you want to extend the cut
    5) use that wire frame to create a surface
    6) select the new surface as your drive surface for your toolpath
    Bottom line BobCAD's toolpath is being driven by the selected geometry. Make adjustments to the geometry changes where the toolpath with go.
    If you would like to see a step by step example of this, send me your file and join the BobCAD After Dark Facebook Group, I'll do a live video on your file tomorrow. ( shown in V33, but much of the workflow will carry over to V27 )
    BobCAD EXTENDED BOUNDARY HELP-bobcad-dark-group-image-jpg
    https://www.facebook.com/groups/bobcadafterdark
    BobCAD EXTENDED BOUNDARY HELP-2-jpg
    BobCAD EXTENDED BOUNDARY HELP-3-jpg
    BobCAD EXTENDED BOUNDARY HELP-4-jpg
    BobCAD EXTENDED BOUNDARY HELP-5-jpg
    BobCAD EXTENDED BOUNDARY HELP-6-jpg
    BobCAD EXTENDED BOUNDARY HELP-7-jpg
    Attached Thumbnails Attached Thumbnails BobCAD EXTENDED BOUNDARY HELP-1-jpg
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
