Gap between tool and holder in backplot and sim
Results 1 to 7 of 7
Thread: Gap between tool and holder in backplot and sim
    Member GCSRT's Avatar
    Sep 2020
    Default Gap between tool and holder in backplot and sim
    So I made a custom tool and modified a tool holder. When I change the protrusion length, all it does is change the gap between the tool and holder. This won't work for collision checking. I am using V31 Bobcad.
    Thanks for any help!
    Sep 2020
    Default Re: Gap between tool and holder in backplot and sim
    Version 32, sorry...
    Ghost BurrMan's Avatar
    Dec 2008
    Quote Originally Posted by GCSRT View Post
    Can you show a screenshot of the geometry you used to make your custom tool?
    Sep 2020
    Hope this works!
    Attached Thumbnails Attached Thumbnails Gap between tool and holder in backplot and sim-capture2-jpg   Gap between tool and holder in backplot and sim-capture-jpg
    Member aldepoalo's Avatar
    Mar 2012
    This videos shows the steps I've used in the past.
    If you are running V33, why not create a tool on the machining cloud and just import it?
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Mar 2012
    In that case I would recommend updating your tool profile, making sure to extend your tool geometry for the proper protrusion length. I would need to talk with the support team for the proper workflow.
    Al DePoalo
  7. #7
    Sep 2020
    Thanks for the Quick Tip. Pretty sure my tool geo is correct. Here is a screen shot of what I get. The holder always says the same distance away from the tool. If I shorten the protrusion, the back end of the tool gets shorter and the holder won't move down with it. I have a demo version of 33 but ran out of time to try the machiningcloud. Is anyone using it succesfully?
    Attached Thumbnails Attached Thumbnails Gap between tool and holder in backplot and sim-capture3-jpg
