...V23 BC post files but, I never used them (untested)
Hi Guys,
Anyone have the Siemens lathe posts from the old PP library? They're all crap but I could do with a starting point to edit rather than writing from scratch.
I should have systematically downloaded all posts when I considered doing a year or so ago as BCC have now "Lost" (Deleted) the lot and support have informed me that I can simply buy a new version to get access to a shoddily thrown together PP for the latest version!
- Need Help!- Posts for Fanuc 6T , lathe
- Need Help!- Lathe Posts to Mach3 Mill?
- Lathe c-axis posts
- Lathe Tool Posts
I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
Thanks for those, still looking for a Siemens Lathe post if anyone has one?
[QUOTE=machinehop5;2403442]...you do know there is a App called LatheEditPost.exe in BC. its a little tricky but, you can make what ever PP you need.
Yes,
Thanks, the reason I'd like to start from a Siemens post as the canned cycles, although BC usually got lots of the passed parameters mixed up, will be present,
Regards,
Nick
