Hi David
Have you tried creating a Form Tool the size and shape you need ?? You just draw half of the shape and then you can create a new tool in your Tool Library and "Assign Geometry" and the tool will be created to your drawn shape, see images below
The above is just a rough example to give you an idea of the steps required, hope it helps you some
Regards
Rob
