Need Help! Bobcad 21
Results 1 to 2 of 2
Thread: Bobcad 21
    Mar 2008
    Default Bobcad 21
    I have an old version 21 Bobcad. We actually have a newer version but I like the older version. I am working on programming a cnc lathe to run multiple G32 threading cycles at slightly different starting points to form a shape. I have it set up except for one issue. I need a G00 at the start of each cycle with my new Z value but I need to remove the x value. So my generated code looks like this.
    G32 X8. Z-2.5802 F .866
    W -10.
    X 8.2
    G00 X7.9959 Z-2.6052
    G32 X7.9959 Z-2.6052 F .866
    But I need it to remove the X value in the G00 line for every new starting point. So I need it to look like this.
    W -10.
    X 8.2
    G00 Z-2.6052
    Any ideas how to do this in my post without having to delete The x value manually for each new starting point?
    Mar 2008
    Default Re: Bobcad 21
    I am using a G71 cycle that I modified like this,
Bobcad 21
Bobcad 21
Bobcad 21
