Need Help! Program getting stuck sometimes?
Results 1 to 4 of 4
Thread: Program getting stuck sometimes?
    Oct 2017
    Default Program getting stuck sometimes?
    Hey everyone, hope you are all doing great.
    I’m having an issue where I will run a program and it will run fine for maybe 1 run, maybe 20 runs. Sooner or later it will get stuck on line 3 and never do anything. If I stop the program and reload it, it won’t work. The only way to get it working again is to reload Mach 3.
    I’m calling the gcode that bobcad gives me a “program”.
    If it gets stuck on line 3, the status will usually say which end mill I’m using. If I just hit start run again like I would if I changed tools, nothing happens.
    I’m not really sure what’s going on. Any help or advice is greatly appreciated.
    Attached Thumbnails Attached Thumbnails Program getting stuck sometimes?-9b0a999c-8a49-4551-b229-8a771f62dd28-jpeg   Program getting stuck sometimes?-cc4e3c66-031e-4273-9d0d-6adab2f949c2-jpeg
    Member aldepoalo's Avatar
    Mar 2012
    Default Re: Program getting stuck sometimes?
    Not sure this is a BobCAD issue, I would recommend hitting up the mach group and see what those guys say.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Oct 2017
    Quote Originally Posted by aldepoalo View Post
    Ok, thank you.
    Feb 2013
    United Kingdom
    Al is spot on here, if your program runs OK a couple of times then there is noting wrong with the code, it's your controller that's causing the issue.
    I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
