Sounds like a read write issue.
Please Help. Bobcad encounters an error and closes the program when I try to open a file. Running Windows 7 Professional. If I log in under a different user then it Works fine. Has anyone else experienced this problem?
- Need Help!- Attempting to Make a Mold in BobCAD V26
- Problem- Bobcad V23 won't open (running XP)
- Need Help!- Bobcad V23 Won't Open
- Newbie- Open AutoCad .dwg File in Bobcad v.21?
- Need Help!- Bobcad Will Not Open.
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
Any suggestions on how to fix it?
If you are the "Administrator" for the PC/Network try removing the offending User and then either try re-creating that User Name or create a new one. Or have you tried setting BobCAD to "Run as Administrator" ??
Regards
Rob
Much Thanks to Al . He suggested to open file with merge instead of open and that worked!!! Now I tried to open with open and that worked too. Thanks again Hope this helps someone else too.
