Need Help! Bobcad Cam Lathe V32
Results 1 to 3 of 3
Thread: Bobcad Cam Lathe V32
    Nov 2017
    Default Bobcad Cam Lathe V32
    Hello,
    Running a Cnc wood lathe with a knife cutter. Is it possible for Bobcad Cam to make a single depth profile turning cut ? ( no multiple passes) . If so what would’ve be the best way to preform this operation?
    Thank you.
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    Default Re: Bobcad Cam Lathe V32
    Yes, however that would have to be a single "Basic Finish" strategy, see image below.
    Bobcad Cam Lathe V32-lathe-basic-finish-path-jpg
    Bobcad Cam Lathe V32-lathe-basic-finish-path-2-jpg
    Hope that helps
    Regards
    Rob
    Attached Thumbnails Attached Thumbnails Bobcad Cam Lathe V32-lathe-basic-finish-path-2-jpg   Bobcad Cam Lathe V32-lathe-basic-finish-path-jpg
    Nov 2017
    Thank you!
