Solved Post for K40 laser cutter
Results 1 to 1 of 1
Thread: Post for K40 laser cutter
    Member Bazzer's Avatar
    Apr 2016
    United Kingdom
    Default Post for K40 laser cutter
    Over the weekend I installed the Scorchworks K40 Whisperer control programme on my cheap and nasty Chinese K40 laser cutter, wow what a revelation the K40 Whisperer programme is!!
    One of the nice things with the Whisperer control is that it can read G codes, there is a short tutorial video that Scorchworks put on you tube and within that video the basic G codes used can be seen.
    I though I would tweak a Bobcad post to churn out G code for the K40 and that has been very successful.
    The post is working on V30 and obviously use with caution but it has worked well so far, it is attached if any one wants to use it.
    Regards
    Barrie
    Attached Files Attached Files
    Barrie @ Composite Specialities Ltd. using BobCAD V30 Mill 3 axis Pro, Bricscad V14 and MOI V3 with CNC-Step High Z 1000S and Wabeco CC-F1210
