Need Help! bobcad v 31
Results 1 to 8 of 8
Thread: bobcad v 31
    Mar 2009
    Default bobcad v 31
    now that i have v31 installed i can no longer back plot with predator. i have a pro licence with edit nc but the verification is now grayed out. before today it was functioning.
    Attached Thumbnails Attached Thumbnails bobcad v 31-edit-nc-jpg
    Mar 2009
    Default Re: bobcad v 31
    Hey Al how about a video showing us how to use the job setup feature on NcEditor. i figured out the stock but not sure how to setup tools.
    Thank you.
    Nov 2012
    I’m a newbie to bobcad but am also having trouble with the tools.
    Member aldepoalo's Avatar
    Mar 2012
    There is a string of code that you need in your header to pass the stock and tool information to the editor. I would start there.... If you haven't sent your post processor to support to be updated to V31 I would do that as well.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    No posers SBC Cycle's Avatar
    Apr 2008
    Quote Originally Posted by 1234567 View Post
    Thank you.
    I'm not sure I saw it in the video that Al posted but you usually don't need to edit the job setup in the NC Editor. I added the following to my post processor to get BobCAD to generate a call to the job setup that is created automatically:
    Code:
       comment_start,"JOBSETUP[",prog_name_no_ext_no_path, force_no_add_spaces,".mwjs]JOBSETUP",comment_end
    I ripped this from the existing example posts in the V31 data folder after noticing most of the example files had this line of code. Here's what it looks like in the NC code:
    Code:
    (END PREDATOR NC HEADER)
    O00500 (TC_ANGLED_3D.NC)
    (PROGRAM NAME - TC_ANGLED_3D.NC)
    (POST -  Haas 3x_Mill.BCPst)
    (DATE - WED. 08/07/2019)
    (TIME - 03:08PM)
    (MATL - Wrought Alum 6061-T6, T651 (95 HB))
    ( JOBSETUP[TC_angled_3d.mwjs]JOBSETUP)
    G00 G17 G40 G90 G80 G54
    Mastercam X9/2018 Multiaxis for SolidWorks - Bobcad V21-V30 3ax Pro 4ax Std.
    Apr 2009
    What Up SBC
    are you back with BoB?
  7. #7
    Mar 2009
    thank you!!!!
  8. #8
    Apr 2008
    Quote Originally Posted by jrmach View Post
    What Up SBC
    Living the dream my friend, hope all is well with you! I'm still using Mastercam for Solidworks as my main programming software but I've never stopped using Bob. I have thousands of parts that I maintain as an OEM and by far the majority were programmed with BobCAD. When I need to make a revision or I think it can be improved, it makes sense to work in BCC rather than start from scratch.
    I'm using V31, so it's like I never left!
    I'm still active learning and helping when I can but I mostly use the Facebook groups because I'm already on there when I'm screwing off, lol. Not much time for screwing off these days, by the end of the year my father will be fully retired and I've been assuming his duties.
    If you do Facebook you should check some of the groups out, Al does live video frequently.
bobcad v 31
bobcad v 31
bobcad v 31
