Run the simulation and save the stock out as a solid model, import this as the stock for the next op.
in the 3 pics, one side I am going to remove the material from one side as shown with the tool path, then I am going to turn the piece 45 degrees and need to cut the small groves. how do I cut the grooves without cutting so much air?
David L. Aery
www.hooksolutions.com
I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
Wow, thanks!
I never would have thought of doing it that way.
David L. Aery
ok I have 2 machine setups. In the pics the first setup the side is the top, then after it cuts the side I thought it would stop so I could re-position the part when it goes from one machine setup to the next but it did not. the simulation runs as it should.
David L. Aery
ok, thanks, I'll try that.
David L. Aery
