Use Work Coordinate Systems, it's mainly down to planning, reference points on work, stock or both, work stops and accurate set up though.
I have a part that needs to be milled on the top and then turn to where the side faces up and then mill that side.
I don't know where to look in help how to do a different setup.
Where do I start to find out how to do this?, is this in the "stock wizard"
- Dust collector setup,dust hood setup,power connecting
- Need Help!- Visual Studio 2015/2012 Template setup for NX10.0 & Custom folder setup
- Need Help!- kia superturn 21 yasnac J50L tool setup and part orgin setup thx
- Free MastercamX setup sheets for milling free 3 axis milling active designer setup sh
- Looking to buy my first CNC setup. Thoughts on this Partner III / Cent IV setup?
David L. Aery
www.hooksolutions.com
I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
If your machined side doesn't lend itself to be being held in a vice for the second op you can machine a soft jaw which will support it derived from your part geometry or that of the machined stock saved from a completed simulation run.
thanks, i found a video by Depoalo of "Multiple Machine Setups "
this is what I was looking for, this makes it look easy but I am having some trouble with my orgin.
I think I can get it now.
Thanks!
David L. Aery
I actually got it to work
David L. Aery
Excellent, that's great to hear!
