Need Help! How to copy V26 files to V30?
Results 1 to 4 of 4
Thread: How to copy V26 files to V30?
    Dec 2012
    Default How to copy V26 files to V30?
    I recently bought a new laptop.Bought V30 and had it licensed on that computer. Then I had licensed V26 and V27 transferred from old computer to new computer. Tech told me all my old files would come with the transfer. Some did most did not. How can I get these old files on the new computer V30 ?
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    Default Re: How to copy V26 files to V30?
    Probably the simplest way would be to just copy the files on to a Flash Drive and use the drive to transfer the files to the new computer and save them to the required locations, however that is pretty labour intensive and could take some time if you are going to be saving lots of different files to different locations.
    It would be much quicker if you can set up a small network with the old and new computers and then it would be much easier to move files from the old computer to the new one as you can send the folders containing files straight to any desired location on the new computer.
    If you are not sure how to do that your local computer shop would be able to do it for you quite quickly and easily and it shouldn`t cost too much
    Regards
    Rob
    Member machinehop5's Avatar
    Aug 2009
    adding to Engine Guy ideas.
    ...maybe you already know this easy trick ......you can find all your old Files by just Typing in Windows "Search" box with wild card (*) and the extension (*.bbcd ) (*.dxf) (*.iges) (*.txt) etc etc
    Feb 2013
    United Kingdom
    If you were using the default folders for storage most of the files saved from BobCAD should be in
    C:\BobCAD-CAM Data\BobCAD-CAM V26
    and
    C:\BobCAD-CAM Data\BobCAD-CAM V28,
    post processors etc. will all be in there too in the relevant sub-folders
    I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
